I have a 2002 2 stroke mercury 115. It has an alternator driven ignition. The motor starts and runs fine initially. After a half hour or so, when running at any speed above idle, the motor will act like you are running out of gas. You can idle for a few minutes, take off again, and you might de able to run for 5 minutes or 30 seconds. The problem seems heat related, since I have never had the problem happen in the first 30 minutes or so.
i put a portable fuel tank with a new fuel line,bulb, and fuel on board to try to eliminate my fuel system with no help.
have inspected wiring from trigger and stator with nothing obvious. Does anyone have any suggestions on how to troubleshoot this problem? Thanks!
