Captain Tinnie
I have a 2005 2 cylinder 2 stroke 40hp Mercury outboard which is loosing oil from it's resevoir. I have unassembled and inspected the plastic tank and there are no leaks from the bottom outet or sight tube sites, the outlet hose to the oil pump is not leaking but have not yet pulled the oil pump off. The motor is in the down position and I have not noticed aoil oil leaking from the bottom cowling or parts of the leg, but the oil must be going somewhere. Are there some valves in the lines or oil pump? Parts for these older models are harder to find (in Australia) so what are you thoghts on removing the oil injection system all together and using a pre-mix. Thanks in advance for any help, Fred.
