This is what comes up for the
Edelbrock E-
Street Power Package Top End Kit's For SBC.
Aluminum cylinder heads and aluminum intake manifold. This intake is dual plane, of which works well for the Marine version SBC.
However, neither will fair well unless your engine is equipped with a closed cooling system due to the PH unbalance of sea water.... be it salt water, or river/lake water........ it just won't work for any length of time.
Your 1998 Mercruiser 5.7 L will be OEM with the full dished pistons. This typically dictates 64cc cylinder head combustion chambers.
If you were to switch cylinder head combustion chamber volume, this must be factored in.... unless you also change pistons.
As much as we wish this was NOT true, there's not a whole that you can do to increase performance with a change to intake and carburetion alone.
The true performance values come from within deeper into the engine.
IMO, if you want a performance increase... which may include some economy improvement......., stay with the GM Vortec 64cc chamber cylinder heads. Tear the block down, and remove the full dished pistons.
Purchase and install a quench style piston that closely mirrors the Vortec combustion chamber "wedge" area.
http://www.kb-silvolite.com/images/feature/KB735_700pix.gif
This style piston creates an effect that the OEM full dished cannot offer.
A good piston manufacurer sales person can offer you the correct p/n pistons for your application.
With the correct piston underneath the Vortec chamber, and with the correct compressed head gasket thickness......... you'll gain a quench area, aka "squish zone". The Quench Effect allows for changes in Ignition tuning that will benefit low end torque characteristics.
Nothing to the C/R or other engine components requires a change.
See this thread for more info.
Green arrow points to the quench area or squish zone.
Red arrow points to the dish volume that controls C/R.
