Are we talking about the AQ series drives?
This is much more involved than Long/Short hub, and goes into the drive model.
250/270/275 require the short spacer/line cutter.
280 and later, require the long spacer/line cutter.
NO substitutes.
Either nets the same prop shaft exposure when the correct spacer is used.
Early 280 and all 270's and earlier, are not threaded for the spinner keeper bolt.
This means that the long hub prop is not easily adaptable to a non-internally threaded shaft, since the shaft splines do not sit proud of the hub.
Of which means that the SS tab washer cannot be used to secure the spinner.
Now.... there are both long hub props......, and long blade hub props.
The long blade hubs do not necessarily have a long inner hub.
The long blade hubs will generally offer the tab washer slots (in order to reach in and bend the tabs).
Of the prop shafts that are internally threaded for the spinner keeper bolt, any combination can be used as long as the two pc spinner is used.
Short hub uses both pieces of the spinner.
Long hub uses the AFT-most piece of the spinner w/ the keeper bolt.
If you were to own the two pc spinner, you've covered all bases.
Make sense?
