SuperBeeIII
I've run across a bunch of threads here with a Google search that are related to an issue I'm having. Apparently, I do not have the correct Prestolite distributor in my "Super Bee III" powered Chrysler S-III.
I see a lot of discussions about only finding the base timing spec for these marine engines. I have an original LM340 Chrysler Marine Engine Service Manual that may shed some light for those looking for factory distributor advance curve specs. Note there are two sets of specs apparently depending on the part number of the installed distributor. I have no idea why there are more specs for the second set of numbers. Also note these are "distributor RPM" and not engine RPM specs.
Here's what it shows:
DISTRIBUTOR
Chrysler Part No. 2444983
Advance (automatic centrifugal)
Distributor Degrees at Distributor RPM 0 @ 275 to 425
0 to 7.5 @ 425
6 to 8 @ 550
Chrysler Part No. 3438830 and 3675973
Distributor Degrees at Distributor RPM 0 to 2.5 @ 450
5 to 7 @ 600
8 to 10 @ 700
11 to 13 @ 1600
13 to 15 @ 2200
DISTRIBUTOR
0 to 7.5 @ 425
6 to 8 @ 550
5 to 7 @ 600
8 to 10 @ 700
11 to 13 @ 1600
13 to 15 @ 2200
