LM318 chrysler reluctor setting
S
Scott Fuller
Guest
"I have a LM318 225hp sea Bee
"I have a LM318 225hp sea Bee sterndrive 1983 with electronic ignition.
1. What is the reluctor to pickup gap setting?
2. How do I remove the old reluctor?
Regards, Scott."
"The new one I bought came wit
"The new one I bought came with specs, I will see if I can find them. I always used a little PB blaster on the dist shaft then two flathead crew drivers to pry it up against the dist body.
I was also told to use a non-ferrous (brass) feeler guage to prevent damaging the pick-up or reluctor not sure if this is important or not but I did and my runs great.
will"
"Use a non-magnetic feeler gua
"Use a non-magnetic feeler guage (brass or plastic0. A .006" should pass, a .008" should not. Be sure to make a final check after the hold down screw is tightened."
