LM 318 Timing
stuski
Does an engine that has had it
Does an engine that has had its rotation reversed use same timing mark that is cast into timing cover? With piston #1 @ tdc mark is way off. However rotor seems to be at #1 plug wire @ distributor.
"Yes, but you use the other si
"Yes, but you use the other side of the metal tab (unless it's rusted away).
Jeff"
