little johnson needs alittle help
mudsucker3006
the model a '93 j 25 teets. new plugs,clean filter in clean tank,clean screen @ newly rebuilt fuel pump.good connections & primer bulb pushes alot of 50:1 fuel through new line. My gig is,the engine will idle, but will die if accelerator handle is turned to idle faster.
Who rebuilt the fuel pump?Have you disconnected the fuel pump outlet and checked for fuel out to carb?
