I have a 16.5' CC with an 86 Yamaha 2 stroke. I cleaned the gas tank, carb, fuel filter 4 months ago. The engine runs good until a few nights ago that it idled very low, even after it warmed up. Sometimes it just shut off by itself even at higher RPM. I knew this is not normal. Today I open the carbs and clean them and found signs of water in the bowls. So I clean out the carbs. I open up the fuel filter at the engine and there is 1/4 of the cup filled with water. I removed the water separator and saw rusts and milky stuff inside the filter. I pour the gas out and sure enough 1/4 of the liquid was water. I replaced the water separator and it runs perfect again. The point is listen to your motor. If it shows sign of abnormal then check the fuel and clean out everything fuel related.
PS. I just remembered that a month ago I ran the gas tank all the way down. This probably caused the motor to suck the water out from the bottom of the gas tank. Even though I cleaned out the gas tank a few months ago I think the water went back into the gas tank via the vent hole. I check the vent hole on my boat and it's wide open. If any wave hits it the water will enter the tank. I am putting a cover over the top of it and clean out the gas tank one more time.
