mostwanted-lkpg
I have a "new" motor, a 1991 50Hp, 2cyl Johnson. The problem is that I cannot get it to run on slow RPM´s . I took off the cover and tried to adjust the idling set screw and noticed that it didn´t even touch the stop.
So I believe I have to do a link and sync?
Here´s 2 pictures how it looks on "no throttle, no gear" and in WOT
Green ring; there is a big gap between the roller and the roller cam(?) maybe 0,30" gap, space. Shouldn´t it be tight? And the two arrows, they roller never lines up with them?!
Yellow ring, idling set screw? As you se , its hard to adjust when it dont evcen touches the stop?
Blue ring, how do I know where it should be?
Red ring, I have now adjusted so that the carbs are opening fully at WOT.
