"With some good instructions,
"With some good instructions, I managed to remove the shift/throttle lever (3.0L Mercruiser) and repair a cut wire that was killing the down side of my trim button. However, like an idiot, I failed to mark the position of the lever when I removed it. Now after slipping it on and off and messing with it, I'm not sure where it needs to be. I'm assuming if I moved it to a position of putting the linkage in the rear in the neutral position, I could then put the lever back in the neutral position. Any suggestions?"
