Line cutter spacer rattles
fishinray
Took my prop off my 280 VP. Th
Took my prop off my 280 VP. The wire cutter spacer was arched in 4 spots. What can you do to hold it in place when you assemble it. Do you have to get a new one and spot weld?
line cutter and spacer/ thrust
line cutter and spacer/ thrust washer should be in one piece. welded. replace it.
So you're sayiny the cutte
So you're sayiny the cutter is electroded to the spacer and I should have pull the spacer with the cutter attached?
