Lilb bigfoot gone wild
D
douglas rollins
Guest
"I put my 9,9 in reverse the o
"I put my 9,9 in reverse the other day and it nearly crawled up outta the water! There's a two piece plastic latch down there with fancy springs. The hook engages the pin but that big piece with the spring doesn't seem to be doing much. It's an 01 & nothing looks broken but things aren't going together down there when I drop the motor in. Any suggestions?
dw"
"Douglas, let's see if I c
"Douglas, let's see if I can help you here with a little diagram. Your motor should lock itself down when in reverse (you don't want it locked in forward incase you hit something - otherwise you could tear off your lower end).
Anyhow, when the motor is in reverse a guide on the shift shaft should push a linkage rod into a position where the end engages the lock.
I would suspect that your linkage is either 1) out of adjustment or 2) has jumped out of where it belongs (on either end).
Have a look at the diagram and then play around with your motor a bit, observing what happens as you switch it between neutral and reverse...
(the pic is kinda sideways with the upper left being the top of the motor)...
Thanks Mr. Lamb! I'll try
Thanks Mr. Lamb! I'll try that and adjust until it stays (reverse only)
thanks again
dw
