willys_wonka
Hey all, Ive got a Yanmar 4JH2E with unknown hours (but assume pretty high). I'm concerned about it smoking. Blue smoke, especially on start up but even when warm there's a noticeable amount. Now I've seen some boat diesels that have enormous plumes when starting and running and this is nowhere near that. I never have to add oil between changes.
Usually blue smoke means worn cylinder walls and piston rings - time for a rebuild. But this engine starts instantly - I mean instantly, even in the cold of winter. No glow plugs, just hit the starter and in a fraction of second it roars to life, like a new engine.
Now generally, worn rings also mean lower compression and a bit of grinding on the starter to get a diesel going, with a big puff of white smoke on startup. Not this engine. So what's going on? Valve stem seals will cause smoke on startup but usually not while it's running.
Ideas?
Ideas?
