skip right to the chase. Have 2006 Monterey 248 montura whit a Volvo penta 5.7 gi-e. Been having some troubles. The enginen throws audio motoralarm. This happens when the boat has been running for 20-30 min. I have timed it and it's always in this timespan speed or drivestyle doesn't matter. Just Before I get the alarm I can fel the motor running a little bit rough on low rpm about 2000. The alarm reduce power over 2500 rpm. It sounds a little bit if the engine is not working at all cylinders. I have done some shotgun repair whiteout success. I have replaced, termostat, IAC valve, checked 3 spark plugs that seems OK, measured that both temp sensors and exhaust sensor are not causing the alarm. Changed impreller. All gauges on dach are OK Whit solid readings. I'm now gonna proceed to check ignition, fuelpump. Summary: no problem starting boat. Hard alarm after 20-30 min every time. Just before hard alarm, engine rough on low rpm. Had this problem since I got to boat in water in juni, someone have any ideas?
Br Marcus
Br Marcus
