"I had a problem with a leaky
"I had a problem with a leaky carb I had water in the gas and cleaned the fuel tank and carburetor, tested on the bench into a garbage pail with water ok running, moved to the sail boat started ok ran and then stopped and started leaking gas out of the air intake. Float stuck any help, should I clean out with carb cleaner?"
