Borg Warner 71 trany behind 35
Borg Warner 71 trany behind 350 crusader. Started leaking. Saw mist/spray pattern up against one of my sanitation hoses about 18inches away from the transmission. I also have drips maybe a tablespoon or 2 on the diapers under the transmission. Marine mechanic at the marina told me that sometimes if I rev or accelerate quickly in reverse it will spray past the seal. I checked my fluid level and i did over fill when i serviced my trans. Does this sound right? If i drain some ATF from my trans should this stop or did i blow out a seal? Trans was completely rebuilt 2 years ago.
