Leaking Rainbow fluid from the outboard
briannad
I have a 2000 four winns Vista
I have a 2000 four winns Vista which has a Volvo 5.7 GSI Engine. All of the sudden we are leaking this rainbow colored fluid from the outboard into the water. Does anyone have any idea what could be causing this?
"Sounds like you may have a le
"Sounds like you may have a leaking power trim hose. The rainbow fluid you are seeing is most likely AT fluid, or hydraulic fluid. Pull boat and check hoses. Good luck."
