Just finished installing new Osco risers and elbows on a 1986 Crusader 454. I followed the instructions on several threads in this forum and in the crusader manual. Apart from getting the old risers off, which was a major pain, the rest of the installation went smoothly. After running the engines and and ensuring that everything was operating normally I began to re-check the torque on the studs and noticed that I have several very small raw water leaks coming from the tip of the shorter studs. The water seems to be coming from the head of the nut between the threads.
I have noticed that the three studs that are leaking are slightly shorter than the one that is not. I used new Osco studs, bolts etc but now i am wondering if I installed the studs the wrong way around. Has anyone encountered this issue before, and if so how big a deal is it. The leak is a very slow drip and i have been considering loosening the nut and placing some sealant on the threads, to see if this will stop the leak.
Any thoughts?
Any thoughts?
