Late 80s Johnson 70hp bogs and dies when accelerating
Funfisher130
I have a late 80s Johnson 70 hp that idles well and runs at intermediate and full throttle well but it often bogs down and dies when going from low throttle to full throttle. The fuel is fresh and the bulb remains fairly hard. Pumping it does not help. When accelerating, once the motor gets through the spot where it wants to bog down and die, it runs great. will be performing a compression check. Any help would be appreciated.
You may find that the 75 HP models had an adjustable low speed needle .-----------The 70 hp models did not have that as original equipment.
