I've seen others comment of their '95 PCM GT-40. I too had had no problem with this engine until the last two summer. When cold, it starts right up and runs great. After running it far awhile, skiing/tubing/etc. and the engine gets up to speed, and it it sits, it just will not re-start. If I let it coold down below 140 degrees, it will re-fire perfectly. I've replaced both the low pressure and high pressure pumps. Next will be the coil. Someone has to have a solution for this problem. Help!
