Kohler Generator 5E Troubles
NW Cruiser
[FONT=&quot]Hello all,[/FONT]
[FONT=&quot]I just wanted to share some recent information about my 5E Kohler gen.
I'm new to the forum but not boating. I own a 2005 348 Vista and love it. The Kohler 5E gen however? Sometimes not so much![/FONT]
[FONT=&quot]After taking delivery last and with the boat winterized I never tried to start the gen until spring as everything was laid up. The Kohler ran ok during the sea trial but I knew we had a few things to work on as it sputtered.[/FONT]
[FONT=&quot]Ok,come spring. The gen cranked like crazy but no start. She didnt have power to the fuel pump nor spark? I replaced the control board ($245) with new and no go, same thing. Here's what I found.[/FONT]
[FONT=&quot]1.The carb was completely plugged with grit and the anti-diesel solenoid was not working.[/FONT]
[FONT=&quot]2.I found the small inline fuel filter just in front of the fuel pump was plugged despite having a fuel/water spin on filter in front of that.[/FONT]
[FONT=&quot]3. The electric choke was shorted which caused the no spark no power to fuel pump issue. This was obvious when looking at melted connections and a little ohm work.[/FONT]
[FONT=&quot]4. Oh one other thing? If you have a remote start/stop button in the boat say down in the salon, remember it needs to be in the neutral position or you will not be able to start the gen from the bilge. You'll get the ol no spark no power to the fuel pump routine which can drive you batty![/FONT]
[FONT=&quot]These units need clean fuel and need to be regularly run under a load. Fuel problems cause most issues with these units along with plugs. Throttle hunting is most likely plugged jets in the carb.[/FONT]
[FONT=&quot]Keep fuel clean gents and always check fuel, spark and air first.
[/FONT]
All generator faults can be divided into two groups - mechanical and electrical. The first includes the destruction of the device housing, broken mountings, bearings, brushes, clamping springs, overrunning clutch or pulley, and other parts. The second includes breaks and short circuits of the diode bridge's winding breakage, and voltage regulators wear of carbon brushes.
Again, if it is an old alternator, it may have more than one failure. My old alternator did, and so I chose a new one. This is one of the quiet generators since the old one was making an awful lot of noise, which was bothering me.
[/FONT]
I have a question.
I have Kohler 5E generator in my 2005 Sea Ray 320.
I'm confused, last Saturday was the first time I used my generator this season. No problem, it started right up, and runs good. I checked my AC current, perfect 120v.
However, I noticed my 12v system meter was buried at 18v. I shut every single 12v breaker off; no difference. Then I shut off the breaker to the charger, again no difference.
Why such a high output on the 12v side? I though generators only supplied ACV?
My neighbor has the same boat; only difference is his is 3 years older, 2002. We started his, and his 12v meter only went to 15.8v - 16v.
Upset with Kohler, as I sent them a more detailed description, and their response in a nutshell was: "Sorry to hear about your problem. Contact a certified Kohler Marine Generator Service Center, and according to your location" they gave me 3 companies. The closest one was 74 miles away. REALLY!!!! Great response.
Anyone have any idea what the problem is?
