"I have Chrysler 75 HP Magnapo
"I have Chrysler 75 HP Magnapower, I need to replace the key Dash ignition switch (Missing)I have a (386918 Ignition Switch) which has six connectors on one end with little label letters like B, C, S, M, I M, it also has the press to choke option. The outboard motor has a harness with color coded wires which are: Starter-yellow, Generator-Purple, Tachometer-White, Choke-Green, Heat-Orange, Battery-Red, Ignition-Blue, Ground-Black. Can you help in connecting the proper color coded wire to the correct lable letter on the switch, Will I have extra wires, Like the heat, Choke"
