79 Caribbean
I have a OMC STRINGER 351w ford motor, what is the correct part number for the thermostat kit and oring, and can I get a 180 deg stat. For it?
Running holly sniper fuel injection, computer needs to see 180!
Ayuh,..... A fools errand,...... Sell it, 'n put the carb back on it,...... it's a obsolete stringer drive,.....
of which is........ ?????Running fresh water only, guess I’ll have to implement the 2% rule.
Just need to be 2% smarter than what I’m working with
when you find something you love, do what ever it takes to make it what you want!
Bt Doctour said:So just where did you manage to install the sensor that dosen't have wet exhaust running thru it?
79 Caribbean said:I machined a spacer for the riser
I have an inboard outboard that is currently sitting in the water. Can I change the impellers or will water start flooding in when I remove the cover?
