Greetings all,
Recently I picked up a 2002 Pursuit with a 2002 Volvo penta KAD300A turbo diesel (460hrs) and am having some issues with the turbocharger.
At 1500 rpm the supercharger kicks in and then disengages at about 2700-2750rpm where the turbocharger should kick in. Between 2750-2950 the supercharger disengages and re-engages (when pressure drops to much). The boat surges as the pressure fluctuates. If we accelerate to 3100-3200 turbo runs fine and supercharger remains disengaged. WOT is 3650-3690 and turbo is smooth.
She also seems to be burning a small quantity of oil; blueish smoke at lower rpms. Potentially in the turbo?
Any thoughts to what is happening?
So far have:
-pulled the exhaust elbow looks good; minimal scaling
-compressor wheel clean with acceptable gap around between the housing
-turbine looks slightly sooty and ends to blade are NOT linear like compressor wheel; as though the turbine blade is made to fit inside the flange on the turbine housing
-turbine housing inside has some scaling where exhaust elbow is attached; nothing terrible
My gut is afraid that the turbo is shot...!?!
Should the turbine + turbine housing be replaced, rebuilt or purchase all new turbocharger ($$$$$)?
Any experience running Rotella's T-6 heavy duty synthetic oil in these (5w40)? Run that oil in all the trucks and equipment
Other than that she runs smooth!
Any insight would be greatly appreciated!
Thank you
Chris
Miller
So far have:
Thank you
Chris
Miller
