VirginiaBeach
Twin Mercruiser 496HO's with Keikefer 280 tabs. The tab pumps are basaically the same pump/reservoir as the standard Merc drive pumps.
1st issue: On my starboard side the K-plane pump just clicks when at both the up/down position on the seperate rocker switches on the dash. I have cleaned both solenoid wiring connectors. The solenoids are configured a little different than the OD setup, but solenoids/operation is the same.
2nd Issue: Both drives also have seperate trailer rocker switches. Again on the starboard side the trailer rocker switch will only raise the drive. Subsequently, the trim switch on one of the dual throttles (operates both drives simultaneously) will both raise and lower the starboard drive (both sides actually) up/down no problem? So there's an issue with the trailer rocker switch wiring or connector somewhere.
Any thoughts?
Any thoughts?
