just got a new / used boat. stalling when i throttle down. dies
jeff1824
just got the boat it runs great on the open water but when i throttle down the motor dies.any time i take itout of gear it dies, weather it from idlol to nuteral or from reverce to nuteral it dies anything i can look at or fix myself ? its a 1996 baha cruser, moter was replaced in 2010. valvo 5.7 GXI bobtail
thank for any respone
Ayuh,.... Welcome Aboard,.... See's it's a brand new to you boat,....
I'd think a full, 'n complete Tune Up, 'n Service oughta point ya in the right direction of yer issue,...
Are you absolutely certain that the drive is a Volvo Penta, and not a Merc "A" Dog Clutch drive????
The Merc A drive uses what's called a SA... (aka Shift Assist unit)... as to enable a shift from gear back into neutral.
(this SA system actually stumbles the engine's ignition system as the shift is being made)
Volvo Penta drives are "cone clutch" drives, and do not require an SA.
If Merc A drive, and if the SA is not adjusted correctly, or has an issue, your description of what occurs when you throttle down, and/or move in/out of gear..... fits the bill.
If Merc A drive, and if the SA is not adjusted correctly, or has an issue, your description of what occurs when you sthrottle down, and/or move in/out of gear..... fits the bill.
Yes, I'm 1000 % sure it's a Volvo penta. I've had a few people say it could b the cap & roter ? U can almost hear it bog down when I throttle down
