Hello,
I have a 96 175 fast strike having a problem that is getting worse it started, every time I would stop to fish for a bit I would have to prime the ball or the motor will die on take off. Or when I stated the motor it would idle in till the ball got soft then die, I was told it my be in the main tank so I set up a small tank to test run and it would idle but will not run under a load.
So I went back to the main tank and now it will only run if someone is pumping the priming ball.
I replaced the ball, all flue lines, filter, and spark plug.
I will try anything just cant trust the marinas.
