Johnson trim/tilt leaking
billt45
I have a 1982 Johnson 90 hp. I released the tilt screw so I could lift the motor by hand. The trim/tilt continued to work fine for a while after I tightened the screw. Now it is leaking fluid from the screw. It seems tight. Does it need a new gasket? How do I change it and add fluid?
