pauljensenpaul
"let me set the story so far.
"let me set the story so far. 1988 60hp 3cyl johnson outboard. Problem is tilt/trim keeps floating down. Still goes up and down. Pulled the tilt/trim unit beginning of the season this year. got a rebuild kit from my local dealer. Rebuilt the tilt piston (center). Rebuilt the 2 cap pistons. Thats as far as I got. Tried to get into the valve bodies but the allen set screws were stuck and kinda gave me cold feet. Any hu got the unit all back together and back on the outboard with new hydrastatic fluid from northern hydraulics (honda brand). Holy crackers she worked up and down. Manally bled the system with the manual bleeder screw. Thought it was working until it went back to the floating down again. note that this system doesn't leak anywhere, even before and after the rebuild. I understand that it wasn't a toal rebuild, just a half "A" rebuild. Talked to a few local mechs and they talked me into purchasing a new manual bleeder screw, $75 for this screw alone. Needless to say that I was happy when this screw did NOT! fix the problem. Question is since I did that half rebuild, do I get back into the valve bodies and do what should have been done to begin with. Kinda scared about those vavle bodies and set screw.Want to get this fixed and I believe it can be done by myself. Need some help with some guidance. Can anybody take the time and help me with parts, availability of parts,upper echelon publications and/or manuals. Sure could use the help if there is someone out there willing. Thank you for reading this!
