Andrew8807
Hello I have a 1985 johnson seahorse J30EC0A can anyone tell me where the idle screw is to turn it up
I just got the boat this yr it seems to run good but after I drive it for a while and stop to fish or whatever, when I start it back up it seems like it's idling low and will die when put in gear. I have to use the fast idle handle to get the idle up then quickly put it down and into gear and its fine to go.How did this motor run for you last season ?----What trouble shooting has been done ?-----There should be a screw ( #84 ) to adjust idle speed.-----Model # of your motor ?
I can not see , touch or hear your motor.----Trouble shooting begins with a compression test.-----Post the actual values here.-----This shifting at higher RPM may damage expensive
I can not see , touch or hear your motor.----Trouble shooting begins with a compression test.-----Post the actual values here.-----This shifting at higher RPM may damage expensive gear components !
