Bowshark7595
Looking for a little advise or tips. I have a 1980 Johnson Seahorse 7.5 that I recently pick up from a neighbor. The motor doesn't appear to have been used that much and seems to be in very good shape.
However, due to the age, the first step was to replace the water pump and lower unit oil before a quick test run to see if it had potential.
The motor fired right up on the third pull with new gas, fuel line, primer bulb, and tank. It ran pretty good. We then went through the carburetor with a complete rebuild kit. The next test run was much better, but she had a little hesitation at mid throttle when accelerating. I figured we still had some kinks to work out.
The third run wasn't so good. She would start right up, but when trying to accelerate at mid throttle, she would die. At one point, it seemed like it wasn't getting gas through the primer bulb, but eventually I think this was resolved.
If I'm able to get pasted mid throttle without it dying, it runs great a full throttle. It will also idle just fine.
I plan to check the fuel lines under the cowling and the screen in the fuel pump to make sure I don't have any trash or blockage. I may go through the carburetor again.
My question is, is there anything else I should be aware of? Any tips or anything else I should check? Why does it seen to choke out when accelerating?
I really appreciate any tips or information.
