Workin on a 1947 Johnson Seahorse 2.5hp Question is, what kinda compression should I be getting? Also this motor, after it sits overnight, when I start it it will run for maybe 10 sec. then die!
Then will not fire again unless it sits for awhile. Got great spark, compression is 50 psi. I know the fuel is making it to the carb. but unsure if it's going any further than that. Do these motors use reed valves and if so where are they?!?
