Johnson / OMC J2ROEDE needle valve
Chaznsc
Somehow, the NV has disappeared from my little 2.5 Johnson. I noticed the carb was flooding and upon inspection I see the valve has vacated.
What holds these in place and is there any alternative to spending $50 on this part?
thank you
http://www.marineengine.com/parts/j...ROEDE&manufacturer=Johnson&section=Carburetor
What parts are missing there are two needle valves one is the float and the other is the main needle. This looks like an old honda 90 I used to have with the throttle cable. There is a small c-clip to adjust the main needle height and the spring and retainer hold it in place. Did the needle fall off the throttle valve.
I greatly appreciate you responding. The NV I need is for the float, part 19 I think. I must have dropped it when I cleaned the bowl a few weeks back. I know, I'm an idiot. I didn't know about the float mechanism so it's my own fault. It just seems a little overpriced for the part.
Chaz
Yea, I guess that's my best route. I sure wish I hadn't been ignorant about the carb, but whatcha gonna do :)
Thanks again for helping me with this. I sincerely appreciate your time.
