This engine is costing me a pretty penny for the junk it is. It runs great but over 5mph it slips out of gear, I spent $300 replacing the clutch dog and forward gear and its still doing the same thing. I shouldn't even say it's "slipping" because when I back down the rpms the boat starts moving again. If it slipped out of gear it wouldn't move until I put it back in gear. So I thought it might be the prop hub but it doesn't look like this particular model has one, it spins with a drive pin. Could the boat itself be a long shaft boat and how can you tell besides looking at the plate? (took that off so I could use old CF numbers on this new boat hull)
Other info that might be helpful, I recently put on a hydrofoil. I had the problem before but no where near as bad. Could this play into it at all?
