Johnson motor identification
J
Jason F
Guest
" Need help identifying an old
" Need help identifying an old johnson motor. The motor has been painted over and almost all plates are missing.
It is a 2-cylinder tiller, long shaft (31"+/- to prop shaft), external idle and high speed jet adjustment. Motor cover is metal, 2 piece with separate cover to access spark plugs. part numbers on cover sections are 302686 & 302685. Part number on lower unit is 304268. Possible date stamp on crankcase of 8-1-68. "
"Jason;Johnson started using f
"Jason;Johnson started using fiberglass motor covers in 1958/1959,so its older than that.What size {horsepower} do you think it is?Can you e-mail a photo?Spark plug cover sounds like early 1950's or older to me.Try the Antique Outboard Motor Club,www.aomci.org.Good Luck! [email protected]."
