seahorsedad
New to the forum, great place, first post. I was given a boat, Johnson CD-15 motor, and 6 gal. pressure tank. In an attempt to get the motor running after setting 10 years, I have it off the boat on stand in water. Problem is, I rebuilt the tank gasket and diaphragm(with metal primer) but I still cannot get gas to the carb by pushing the primer. Also removed and cleaned the dip tube and the check valve rattles as it should. Is there an o-ring that goes with the primer rod also? I've checked everywhere on the web for info, any help appreciated. I would like to be sure this motor will run so my son and I can do some fishing.
Sincerely,
Donald
