I have a J30 Johnson that I am trying to do the lower unit seals and water impeller. However I can not get the lower unit to come off. I have removed all 4 lower unit bolts along with the nut on the stud on the rear of the lower unit. I have also disconnected the drive shaft just behind the prob. It separates just a little but seems as if the rear stud has corroded itself. I have used WD40 and penetrating oil and a rubber hammer along with heat but it will not budge. Any help with this would be great. I am stuck at this point and my parts will be here today. Any help would be greatly appreciated.
