So ive read about 6 hours worth od info. My problem is lean on gas and overpumping oil. Multiple problems...air leak prior to pump on fuel line side, fuel pump diaphragm bad, fuel pump bad.
Here is my issue. Runs fine once i get it up on throttle. Wont idle right, wont take any throttle. Pump the primer bulb and runs fine for a bit. Can choke it to get it up on plane. I dont get any lack of fuel while running. I dont get any low oil/no oil alarms. Found a gas leak last night from fuel pump area. It has also smoked quite a bit on idle since ive had it. A few times it has stumbled when giving gas.
Question is for those that fixed it while keeping the VRO, what did you do? I have put new diaphragms in both sides of the pump. I like the thought of Variable Ratio Oiling and not 50:1 all the time.
Input may give me more ideas and discussion.
