Converting the pressure fuel system to vacuum:
Mukumi makes plastic and metal pumps and I happen to have the plastic one! Is there anyone who has done this? and is one pump any better than the other? The process looks fairly easy, but I'll explain the proceedure and if any dought out there please contact me...
Remove the (2) two rubber flaps on the lower Leaf/Reed Plate (this is behind the carb.) and plug (1) one of the two holes (useing a vacuum cap) leaving the other hole open. The open hole now gives you a PULSE VACUUM as needed for the vacuum pump to function! Again, all suggestions are wellcome.
