I just lucked into a 1988 Byliner Trophy 16ft center console which I am very happy with. I was able to trade something of little value for it as the original Force 85hp motor was not running and the previous owner was no longer interested in the boat. I don't know anything about Force motors aside from the bad rep they have and I couldn't be bothered to mess with it so I gave it the heave-ho. That leaves me with trying to decide what to do about powering the boat. It weighs approximately 1275lbs says the spec sheet and is rated for up to a 90hp outboard.
I currently have a PRISTINE Johnson 48spl which I also got a great deal on. Now I know this is a little underpowered for the boat but I am thinking If I can get it hooked up that will tide (pun intended) me over until I finish a couple projects and free up some cash to find something a little larger (70-90hp).
The issue is that the only controls I have for the motor are side mount controls. I actually have two sets of side mount controls one of which has tilt/trim wiring which the 48hp does not have. The console on this boat just simply will not work with a side mount control so I am left trying to find or put together a surface mounted binnacle setup. Ideally in the future I would repower by just dropping on a larger OMC engine and leaving whatever controls I have installed in place.
Can anyone give me some advice on what you would do in this situation? When I look on eBay I find very few OMC binnacle controls. The ones that are there are expensive, not in great shape, and Im not even convinced they are the right part for me.
Options I'm considering:
Buying a binnacle control setup if I can find one somewhere and be assured it is the correct part. This would need to have the ignition wiring as well. (The old Force controls are still in place but I am not sure If they will work or if I can do it without everything being massively janky)
Buying just a binnacle throttle control setup and cannibalizing one of my side mounts for the ignition wiring. If this is possible. I am unsure how the neutral safety switch actually works and if that needs to be wired directly into the throttle control box???
Maybe someone out there has the part I'm looking for? Or maybe the part number? Link to the correct part on EBAY?
Any help would be greatly appreciated.
I hope you are all safe out there.
