Johnson Elite 75 Model 75ELR76D Engine acts like sheer pin broken
The inside of the hub is a tight pressure fit rubber insert,once it breaks its hold the hub spins but there isnt enough friction to spin the prop. To check for a spun prop, take a awl and scratch the hub and the prop so the line aligns (hub to prop). Run the motor, rev it in gear then stop and look to see if those lines are yet aligned, if not the prop is called a spun prop and needs either rehubed or replaced,35HP and lower a new prop is about the same cost as rehubing.Larger HPs rehubing is cheaper.
