Johnson Electric Starter
perwel
1986 Johnson 30 - Trying to re
1986 Johnson 30 - Trying to remove the carburator but need to remove the electric starter first to get to the carb mounting bolts. Can't seem to find what bolts hold the starter to the engine block. Any ideas?
"I'm somewhat at a loss to
"I'm somewhat at a loss to understand the question if you have the engine right in front of you, however............
One nut and washer attaches the starter bracket at the front of the bracket to the powerhead. One bolt attaches the bracket from the side of the bracket to the powerhead. One bolt at the extreme rear portion of the bracket faces forward and attaches the bracket.
The starter attaches to the bracket with the two long bolts that run thru the starter.
The bracket and starter must be removed as an assembly first."
Thanks guys. Wasn't able
Thanks guys. Wasn't able to locate the third bolt but with your help the starter bracket assembly is loose.
Thanks again.
