snicklfritz
so here is the story
put new used motor on my bass boat the Johnson command center was taken apart. " i have had some practice with the command center " it seems to me that my cables are binding specifically my shifting cable. i have taken it apart numerous times and found nothing wrong with the mechanics of the command center. ounce it jams i can disconnect from motor and it will still be jammed " throttle only no reverse or forward gears" take it apart put it back together works good for an hour or two. ounce the jamming starts and cables are disconnected i can move handle and watch the throttle cable move and also the shift cable move, shift cable will not move enough for forward and can not put it in reverse at all.
