JOHNSON CD-12 Water Pump Impeller
mrp0722
Good Morning !
Can anyone tell me how the lower unit is disconnected from the mid section in order to change the impeller? Other motors that i HAVE WORKED WITH HAD A PLATE ON THE SIDE THAT YOU COULD DISCONNECT THE SHIFT ROD.
ANY ADVICE WOULD BE APPRECIATED !
MIKE
You have to remove the powerhead for this one .-------Easy to do and a fine opportunity to inspect service the seal under the powerhead.
