Johnson Bombardier outboard
dalejam
Hello I got a boat with the motor last year ran great. This year uncovered it tilted motor down into garbage can full of water to run it .
Then i put key in switch hole turn key nothing . No gauge working . Normally I get the warning horn then speed gage will light up checking oil from pump . But nothing dead .
Can some one give me a place to look . Wire diagram and a year they think the motor is. I’ll buy the manual . Thanks a lot the model number on tag can’t read . Welsh plug says 5007854
Racerone I did check the fuse with a meter and visually it was good.
Fitzz the battery was fully charged had it on charge the night before. I even used my battery tester to put a
Load on it. Said it was good .
So I am looking for a manual to figure out what happend .
Thank you for the reply’s .
Dale
