Johnson 96 4 strokes
ghisroy
"my problem is that my motor s
"my problem is that my motor stops all of a sudden and it seems that the gas doesn't get to it. I verified my pomp and it's good when it's not plugged. When the motor stops on our way, the pomp is not hard. It 's like the motor looses the pression on this pomp.Thank you to answer."
I'm talking about the fuel
I'm talking about the fuel pomp external to the motor: the one that goes from the tank to the motor.Thank you to answer!
"Make sure the tank is properl
"Make sure the tank is properly vented. If air can't get in to replace the fuel as it flow out, you will lose fuel flow."
"May be my problem isn't t
"May be my problem isn't the pump of the fuel because after 30 minutes of running, the motor gets hot but the water from the pump runs ok. Without the top of the motor , it runs good.Thank you to help me!"
