Hi,
I am new to the site and have been searching through to find some answers to my issue. At this point I have not found any that match exactly what I am getting so hopefully someone can assist. Thank you in advance for any help you can give. Now with the issue. I have a 90HP Johnson SPL Model #J90TSLEUA says 1996 on the tag on the motor though from all I can find and have talked to already it is actually a 1997 model. At this point this is what happened. I was going across the lake at about 25mph and started to slow down on the throttle and all of a sudden the motor died and though it would turn over it would not fire. Got back home and next day started troubleshooting it. Tested coil packs with volt meter and the all read around .544 or so and from what I can see on the CDI site they should be .500 give or take. So I then checked for spark,etc and found no spark still. Checked the fuse in the system 20amp and it is good. Verified that with the kill switch disconnected I do not have any spark and the with the yellow wires off of the rectifier and no spark. I checked the rectifier and found it appears to be working as should from what volt meter indicates (reading one way and not the other). I then went ahead and checked the power pack connections and some seemed correct though one did not which was the brown wire to brown yellow wire. I got an open and from what I read on the CDI site help it was supposed to be 450-650ohms. So I bought a new power pack. Put it on and attempted to start and still no spark. I then decided to go ahead and try another battery just in-case the first one or two did not correct the issues. Put battery on and turned over motor and it seemed to fire three times though did not start. Waited about 1/2 hr and then attempted again and now nothing again and from what I can tell no spark again. Anyone got any other tips to check. I am going to attempt to go through the checks again from the CDI help log though want to see if anyone has more things to check. Oh ya also I found that while cranking it over if I push forward on the throttle while still in neutral the circuit stopped cranking, maybe this is part of the issue? Thanks again for anyone that can help me with further testing on this.
Thanks,
Jeremy
Thanks,
Jeremy
