The screw(s) in the connector must be removed, not only loosened. The upper and lower shift rod will go almost end-to-end in the connector.need help. i took of lower leg to change impeller .but now i cant get shift linkage to line up should linkage be in forward ,neutral or rev.tried all positions still wont go on .2 bolts that hold on linkage ,i loosen bott one, right or wrong thanks
