My trim motor is shot, so I bought a new one without really looking at how I will replace it. The third screw next to the transom is unreachable. I've read several options that require releasing the motor from the transom, or knocking the pin out of the eyelet and letting the trim tube swing down. Unfortunately, my eyelet is in pretty bad shape and I don't think it can handle the pounding I will need to do, to get the pin out. My question is, can I remove all the bolts that hold the trim/tilt assembly to the transom mounts and let it swing away from the transom, and be suspended by the rod/eyelet of the trim cylinder?
This is my first post, and I would appreciate any help you can provide.
Thanks, David
Thanks, David
